Themed image Tool sort cycle
Share this page:
EmailLinkedIn
ULTRASONIC microDRILL
  • With ULTRASONIC 2nd Generation and 32.000 rpm for micro drilling with highest process safety
  • Fully integrated regulation of the drilling force in the preset- spindle down to smaller 1 N – independent from the z-axis of the machine
  • ICS with seperate fine filtration and flow rate control starting from 1 l/min
  • Automatic ejector mechanism for drill cores from the diamond hollow drills
  • Drilling diameter from 0.1 mm – 2.0 mm
  • Several thousand holes per part possible without manual interaction
  • Applicable for diamond hollow drills and spiral drills
Left : Fully integrated into the display in the CELOS SideScreen / Right : Precise regulation of the drilling force incl.
Technical data
Machines
ULTRASONIC 50
Controls
CELOS with SIEMENS
● available
      More
